Flat Belting
jimbo8259
Just curious as to how to take proper care of belting. When not in use should it be coiled up or rolled out flat? Should anything be put on to help preserve it? Thanks
DieselAddicted
Re: Flat belting
Roll it up. If it has a hinged splice start by folding it there and you should have a 3-5"hole in the middle depending on the belt.Tie the outer end down with some twine. Store it where mice cant get to it and the drier the better especially if it is leather.
Jebaroni
40
Re: Flat belting
Leather should ideally be rubbed down with Neat's foot oil (available at most farm stores) to keep it from drying out too badly. As for the canvas-style belting, I personally think the best thing is to simply use it periodically to prevent it from becoming too stiff. You may even consider running it for 5-10 minutes on both sides so it doesn't take on a permanent bend only in one direction.
As DieselAddicted mentioned, keeping them rolled up is preferred. Most all of the threshing machines had a reel somewhere for rolling up and storing the main drive belt. I have several corn grinders and I roll the belts up and store them inside the hopper so they don't get lost (also make sure all the corn is GONE before storing the machine).
Old Iron Dave
Re: Flat belting
Any ideas on what to use on a canvas belt that has gone way to stiff to run?
Jebaroni
40
Re: Flat belting
Good question...I'm curious myself. Is it the "pure" tan canvas, or a black rubber belt with a fabric covering? I'm wondering If some form of rubber conditioner would work, but unsure of how $$$ it would be?
Old Iron Dave
Re: Flat belting
I have the tan canvas belt. It's only about three inches wide and maybe only12 feet long (can't tell for sure, to stiff to unroll). It's not worth much, but would be a shame to junk it if it can be salvaged.
Scott
Here's a roll of 1 3/4" belting I just picked up. Only 2 pieces in this roll.
John C. Neagley
We/I always used steam cylinder oil on the pulley side of the belt for dressing while running. Excellent canvas belt dressing and keeps the belt soft.
Avery22x36
While on the subject of belts, someplace, maybe here, I saw a recipe for home made Pullmore? Seems like pine tar and some other stuff was used, anyone know? I got a thresher with all the canvas belts in it, rolled up nice and mice free but stiff as a board, wish I could save them.
eddie bedwell
Hi Team,
both leather and rubberized belt dressings along with other belt jointing methods and so forth have be posted on here before.
I have posted some data previously, but this site only allows a given scan to be posted once.
Maybe a check thru the suggested list near the bottom of this age will find them for you.
Sorry I cannot seem to help further due to the aforesaid limitations on here.
Regards,
Eddie B.
