Found an old MB17 Generator
cornbinder89
Yeah, you'd never turn it by hand, you'll need a bar and socket. Doesn't have an "injection pump per-se" it has a fuel pump either a PTG or PTR (can't see well enough to tell).
cornbinder89
What about the missing balancer on the front of the crank? From the pic's it doesn't look like there is anything on the front end of the crankshaft.
930dreamer
The front hub has the radiator fan, I removed it in the video, or are you talking about the lower disc cradled between the two caps(has zerk fitting)?
cornbinder89
Yeah, the front end of the crankshaft, they normally have some sort of damper on there. Fan drive is just that, fan.
cornbinder89
I'll see what I can find in a CPL book. Just odd that it doesn't have one. The front mount is a saddle type mount used on both the 6 cyl and fours. The front cover has a "snout" that the mount clamps around. One would think a 4 banger would be in more need of a damper than a 6, but both would need them.
Never seen an N series Cummins without a damper, but this is the 1st 4 cyl where I have been able to see the front of the engine.
Normally the front oil seal is pressed on and seals to the inside of the "snout".
Wessone
MB-16, 17, 18, & 19. Brings back some bad memories....why the battery compartment was so high...why the batteries were so heavy. Why were there about 15 steps/panel settings required to start the thing-over engineered is right. Ours had diesel fuel fired oil heaters-greatly needed in central FL. But looks like it should be a fun project. Good luck!
930dreamer
Should I separate the gen from the engine to start? It would be nice if the gen made power but its missing a number of gauges so I don't know.20200202_125516.jpg20200202_125526.jpg
dieselsteveo
I'm by no means an expert on generators, but that engine looks pretty good...like put in fresh fluids and filters and I bet it'll run good. If the generator looks similar, I wouldn't disconnect them....largely because I suck at generator realignment and like to avoid it whenever possible. Why add work? Should be able to disconnect your field coils and prevent the generator from producing any power while spinning until you're ready for it to do so.
If you're willing, please share the engine's serial # off the datatag. I'm curious to know more about when it was made
