Fuel pump problems on IHC 1 1/2 m engine
Gshutt
I’m having issues with a fuel pump that I rebuilt. I put new balls and spring in pump packed to stop sucking air in. I’m getting fuel to pump but I’m not getting enough pressure to go up fuel line to carburetor. Plunger is going down when flywheel is turned.I need someone smarter than me to give me some advice.
Gshutt
Matthew Guy Clarke
Unless the plunger is sloppy in the bore to suck air, and leaks gas, a seat or both seats have to be leaking. Except if line to tank or pickup tube problem.
I take a new ball and drill a hole and thread and put a shaft in it, then hook to drill with lapping compound and lap a new seat in the casting . That should do it.
