G B Essex Brass Drip Lubricator
Garak
I have a G B Essex lubricator on my 1914 Associated which I believe is original to the engine.
The lubricator is looking a little dirty and 'gritty' inside but I am reluctant to try to open it up for cleaning. It still works fine. Would it be OK to half fill it with gasoline to help shift the gunk that as built-up inside over the years?
LCJudge
60
Sure, you can do that. I have taken the spray carb cleaner with the long spout and stuck it down in the oil filler hole. The pressurized cleaner does a good job of cleaning and dries out quickly. You could take it apart and clean the Oiler but I’m sure you would have to buy or make new gaskets.
Garak
Thanks, I did not want to take it apart unless I had to. Do you know what the hook is for that is attached to the filler hole cap?
Bill Hazzard
The hook if for a chain which goes around the center post and it prevents the filler plug from getting lost.
