Gas-O-Lectric Plant
Mike Cushway
Is this engine a Pincor or an Iron Horse? I need to source a head gasket. I have to get a couple 12-24 carb mounting screws and I should be ready to start it. All 4 brushes were seized in their holders. Gas tank was a mess. Carb flange was broken. Points needed cleaning and adjusting. Slip rings and commutator needed cleaning. I spent an hour or so with a soft brass brush and avgas scrubbing. It is looking nice.
NorCalEngines
Re: What do I have?
I believe you have an Iron Horse. It looks like a lil engine that I pick up not to long ago. Mine has no tag or marking's on it anywhere I can find but after doing some research of my own I do believe that is what I have. Compare it to yours and let me know what you think.
Vanman
Re: What do I have?
What ever engine it has on it, that little guy is cool. :cool:
I wonder if you could get Harry to put the Gas-O-Lectric Plant name in the title of the thread?
Keith
MColopy
I have 2 that might have some useful info. It looks like the first one might be like yours, the second one has 7 head bolts.Feel free to get back to me if you need any more info
Mike Cushway
Thanx Harry!
It is just like the engines in the first brochure. It does have the six-bolt head. I got it running and generating perfectly today. I had to flash the field to get it to start generating. I need to rig up a 300w load and set the governor now. I would sure love to find the brush cover for the generator end.
AngrySailor
Iron Horse for sure... or OMC (outboard Marne co.)/Johnson. That’s a neat unit. I have a one half a country away and under a pile of other stuff at my fathers place. It’s newer that yours I’d guess... 12v Gen end.
Make yourself a head gasket, hit up NAPA or whoever and order a 12”x12” sheet. Graphite jointing for steam will hold up, available at any industrial supply.
