plarouche1
New member
Hi, thanks you for letting me register to the forum.
I have a generac 8kw 0056100, the voltage between L1 and L2 is 125 volts ac, and it is 68 volts between neutral and line, the voltage between the capacitor winding is 1,5 volts ac, without capacitor present, with capacitor present it is around 125 volts , capacitor test good, good fluke multimeter, but I am not sure if it worth fixing. I bought it use, the seller had it connected to 5psi propane, guess what happened, he blow out the mixing box. I had it repair and run the generator the 1/2 psi. motor run good
power is low thanks for the advise. ( ps the generator is alone, no transfer box) the seller didn't have it.
Thanks in advance for your input
