Generac NP80D Won't Stay Running
Andrew Mackey
Re: wont stay running
Stick of dynamite or high speed lead poisoning to put it out of its misery.
All kidding aside, i would check the regulator, the low oil sender (if it has one), and the fuel system, including the gas cap - make sure the vent is open. Do you have fresh gas in it?
Wayne 440
New member
If it has "gas" in it, that is a problem - I'm pretty sure that set is powered by a 3 cylinder diesel.
duncanccg
New member
thanks wayne yes its diesel, i have the stator out of this as it appears to be in the windings, do you know where i could get resistance values
