Gray Marine Engine Identify Please
blacktinlizzie
I have had this engine under a bench for 20 years and now it is at the top of my to do list
I am looking for info size model year
I know it is two stroke do you mix or is oil from drippers only
Last off can this engine rotation be reversed
Thanks in advance Bill
Richard Durgee
Re: Gray Marine Identify Please
Your engine is a Gray Marine Model " T".
They were mfgd about 1911 to 1920.
Engines were Gray's top of the line and most expensive two stoke
marine engs. They were a true Two / Three port design !
Had no oilers, mixing gas and oil was just discovered. They were available in
one, two and three cylinders.
blacktinlizzie
Thank you very much
what model carb did it use
This one also had a double drip oiler
Thanks again Bill
Richard Durgee
Model T's used a Krice Carburetor, later engs show up with Scheblers.
If the drip oiler was original to the engine you probably have a 1911-12, by 1913 drip oilers were gone.
It's very possible that faintly etched in the face of the outer flywheel rim is a serial number ( hard to find especially under a coat of paint ) if you can find it post back here and I can date the engine !
Richard Durgee
Harry, on your Gray marine engine article the catalog engine photo is a Model
"R" it was first marketed by Gray in 1908, you can see that the engine is two castings- the cylinder flange bolted to the upper crankcase.
Your engine that shows the rebuilding is the very first Marine engine that Gray designed and manufactured, it was a single casting cylinder and upper crankcase one piece.
This engine was sold by Gray only in the year 1907, and never given a model number only marketed as a 1907. There are a very few of these around compared to the later Gray marine Two strokes.
This is a 1907 Gray Co. illustration and information, you may copy as use it if you choose to !
Harry
Staff member
My Dad, Clarence Matthews Sr. piloting a similar one of these beasts on Cayuga Lake in New York State. (old family photo)
blacktinlizzie
I am looking for photos or drawings of the port or valve that would mount at exhaust outlet sending water out exhaust or returning it to the gear driven water pump to be used to warm engine I think
I got engine running with an adapted Ford model t Carb as orig parts are lost in the shop someware
Thanks for all your help Bill
blacktinlizzie
Yes that is the valve I was talking about mine is just a hole that is not threaded
I am thinking of making a plug machined to port water back to the water supply
Thank You for the photos Bill
---------- Post added at 12:55:49 PM ---------- Previous post was at 12:34:06 PM ----------
That engine is the same as mine
Do you have photos of the other side
Again Mine has fittings one at the crankcase and one on side of cylinder behind timer
Engine came with double drip oiler which mounted with two machine screws above the timer Thank You again for your help Bill
Robt.
Photos touched up. This free program is excellent for photo editing. Or if you just want to use the MS Paint that comes will windows: https://r.search.yahoo.com/_ylt=Awr9CMqnSsZajEkAcq8v7olQ;_ylu=X3oDMTByM3V1YTVuBGNvbG8DZ3ExBHBvcwMzBHZ0aWQDBHNlYwNzcg--/RV=2/RE=1522973480/RO=10/RU=https://www.youtube.com/watch?v=wUKMIi0mInc/RK=2/RS=mmHYIUf6.BmrEsO7bnI3MpR6dtU-
I have the same engine, very nice quality unit with a counterbalanced crankshaft. You're missing the cylinder head cap obviously, but if you want dimensions I can get you those. A metal spinner could make you up one out of brass or copper I guess. The originals were just steel, which wasn't the greatest choice for salt water, though it dents less easily.
There was a cast iron cover over the water pump gears originally. Can get you dimensions of that too if you want.
You've got the engine tag or did someone steal that?
Lots more photos and info on these over at www.oldmarineengine.com Just do a search and you'll see.
177tony
I have a two cylinder, two cycle Gray Motor Company marine engine. Serial number in evidence is 112R9695.. Any information about this engine will be appreciated. Thanks
