Great Explanation Of Anvil Numbering
Thaumaturge
68
Skip ahead to about 13:15 in video
Doc
https://youtu.be/Yocq4iyD0Qk
To address those with slow connections:
Three part number; 1 2 22
1st number is "hundred weight" times 112lbs.
2nd number "quarter weight" times 112/4 or 28 lbs. Never to exceed 3.
3rd number "pounds" Never to exceed 27.
So 1 2 22 = 112 + 56 + 22 = 190 lbs.
Pete Spaco
This. of course, is the British "Hundredweight" system. Usually, the individual digits are spaced apart more than you would see if you simply typed "123" with no spaces in between.
Since there ARE anvils around that use the weight system that we use in the USA, you may have to look close to tell the difference.
Confused?
Example:
1 2 3
Probably hundredweight,
112 + 56 + 3 Then total = 171.
123
Probably USA system,
123 pounds.
Of course the easiest way to tell is if the third number is greater than 9, since, as mentioned earlier, that digit can go as high as 27.
Pete Stanaitis
DBH
Now how many "Stone" is that. The Brit's can screw up anything! That said half my family is from the U.K.!
Dave H.
