Dustin D Ehli
Want to look into building a hammer. Looking at the pivoting leaf spring design cause allows low mounting of the crankshaft and motor.
I have a friend who works in a fab shop so can get deal on all steel and plasma cutting of crank disk etc.
Thinking I beam frame with solid bar all the way to the floor as the bottom die holder, ram connected to the spring on top. Opposite side connected to the crank with a turnbuckle for easy ram adjustment
What I'd like advise on is good working stroke? And if I shoot for 50 ish pound ram what kind of spring pack should I use, trailer springs are shorter than car springs and that would be good I'd think, but what rating.
And what kind of ram guide would be easy to make but keep the die aligned. Greased shaft inside DOM would be easy but wouldn't stop die rotation and that wouldn't work.
Would probably use spare tire drive cause easy and cheap
Ideas welcome. Thanks
