IHC corn Sheller with elevator would like more info if anyone has some ... thanks in advance
Jebaroni
39
That is a rare 2-hole "XL" corn sheller. Most of them ended up with bent flywheels because they were weak. The sacking elevator was optional and very difficult to come by (I have parts of one). I have some parts manual information about these and may be able to lend a little help, if needed. The chain that carries the cobs away is unique. The brackets which allow the bearings to be adjusted are prone to breaking so be careful with them. The hand crank with the gear cast into it is next to impossible to find. Congratulations on such an awesome machine!
mm670
Thanks. I just got it home. I have not rotated it yet.
the elevator has a bunch of crud in the bottom that needs cleaned. The rest moves slightly ok. The cob chain is very rusty so not sure about that yet. Thanks for the info. Will keep you updated
