All,
I am new to this group, and have read many of the pior posts. I have a Jeta Power 15kw three phase generator that was manufactured for the military in 1961. The military designation is MD-151815-WA, and the FSN NO. 6115-617-4919. The generator package only has 1540 hrs on the original Jeta Power hour meter. The generator "package" was designed for three phase only. The generator head is a GE type SJ 12 wire. In studing the documentation that came with the generator, it appears that the genreator can be re-connected for 240/120 single phase. I have been able to determine that it will have to be configured as a Low Zig Zag or Double Delta. I think the best option is to configure it as a Double Delta. Of course, I have not been able to find any information on the pro's or con's of either configuration. The problem I have found in searching the net is that there seems to at least a couple different "standard" connections for these configurations. Does anyone have any information on this type of generator head? Can anyone educate me on which is the best configuration, Low Zig Zag or Double delta?
Also, the engine is a Hercules D-198 diesel that runs great, but it does not have any type of glow plug system. It starts well down to about 50 degrees, then I have to use the ether system that was designed for it. I would like to locate some type of intake manifold heater so that I do not have to use the ether and can set it up for remote starting. I have considered using the intake manifold air heater from a Dodge Diesel pickup truck. Does anyone have any experience with retrofitting an air heater to these engines? I use this generator most every day to top off the storage batteries that I run the shop off of during the cloudy winter. It also supplies power to the shop while it is running. Any and all help/information on the generator/engine will be greatly appreciated.
Mitch
Mitch
