JLO Single Cylinder Mystery Motor
Dale V
New member
Trying to ID this motor, the gentleman I got it from said it was one of the first JetSki motors. It has a Twist grip like a motorcycle attached to the carb. The motor plate has SIBA on it and I did a search and no luck. Searched the actual motor number no luck either. I do not think I have all the parts for the waterpump side. Any info will be appreciated.
Re: Jlo single cylinder mystery motor
Have you check Kawasaki's site for info? I believe the skidoo was manufactured under their name.
Harry
Staff member
https://www.youtube.com/watch?reload=9&v=zaCJ1Jx1gW0
Engine JLO ILO M200V with SIBA start-up ignition system and engine running.
The engine crankcase needs oil for the crankshaft? I know this engine is two strokes and it use the proportion oil/gas, but when it was started the engine then crankshaft blocked. I saw under the engine a drain screw I suppose is lubricating oil for the crankshaft.
Sounds really good - so should his engine JLO ILO M200V with SIBA starting-ignition light system, engine is running.
https://www.youtube.com/watch?v=UnsM8yg8xPE
Engine JLO ILO M200V with SIBA start-up pilot light system, setting the ignition timing and the points.
https://www.google.com/search?client=firefox-b-1-d&biw=1585&bih=926&ei=msjGXYuqDKLa5gLN6r-wAg&q=kawasaki+"jlo+engine"&oq=kawasaki+"jlo+engine"&gs_l=psy-ab.12...9662.9662..12269...0.2..0.67.67.1......0....1..gws-wiz.......0i71.4JSwWpWAfUQ&ved=0ahUKEwiL38uTp93lAhUirVkKHU31DyYQ4dUDCAo
I like oldstuff
If it wouldn't turn over yeah it probably got a slug of fuel due to a leaky carb. In that case pull that plug and drain it out! Sometimes these plugs were used to connect a hose for crankcase pulses to an impulse type diaphragm fuel pump.
Dale V
New member
No I have not, but will research that, thanks so much for the lead
Regards Dale
