John Deere 6hp E Parts Needed
JerryJ59
does anyone know someone making reproduction c524r primer cups,e17rt rocker arm,k2452rt choke plate for a 6hp e john deere?;Mitch at Lightning Magneto does not have these parts;also could use a good ag56rt front axle for the factory cart
Rudy
Y
You could try Jim White from Cedar Hill MO. Ad on sponsors page.
Mike Monnier
Hoarder
43
The primer cup is a Roberts. They pop up from time to time on here or Ebay. Sometimes you can find one reasonably priced at a show if the seller doesn't know what the application.
David Babcock
66
I BELIEVE I HAVE A PRIMER CUP BUT PROBABLY HAS WEAR. DB.
Jim White
If Dave does not have a primer cup, I should have one .I am going to get some rocker arms cast.
Jim White
Jerry,
The Roberts priming cup (extra) is identical to what is on my 6 HP JD. Has a short piece of pipe that screws into the block, and 90 degree elbow and the primer screws into the elbow. Typical Roberts cup with a 45 degree lid and vertical handle. The extra carburetor does not have a choke plate.
Will be sending the pattern off tomorrow for the 6 HP rocker arm castings. I paid $50 for the Roberts, and do not need it. Will take $50 plus shipping.
Bought a load of engines in NE a few years ago and the guy had a lot of JD parts, so I bought all the parts.
Jim White
JerryJ59
Jerry,
Jim White
YOU WOULD BE SHIPPING TO,61036,LET ME KNOW THE TOTAL PRICE,SO I CAN SEND YOU A CHECK
