John Deere B Engine Components
jmholland
I am well into restoring my 1940 B and have a question. The shaft the rocker arms are on is very worn and needs replacing. What material should I use? I have on hand some 4141 chromoly material. Will it need heat treatment?
JHolland
FWurth
One Millionth Post
Re: john deere B engine components
Did you try one of the Deere parts outlets? It may well still be available from Deere. Some site sponsors and advertisers in the antique tractor magazines may be helpful as well.
