Just don't know about this air cooled...
maak
i recently acquired this motor, i need some help.
i cant seem to figgure out what it is for sure.
it has no name or number tags. no cast #`s
or stamped #`s .
Dan Baalman
69
Re: just don`t know
More pictures might help. Looks like it might be an early motorcycle engine. Any carb or ignition parts with it?
Frank17
Re: just don`t know
Looks to ressemble a Smith Motor Wheel...not enough pictures. But i can tell that it is a motorcycle engine of some sorts.
Chris J
Re: just don`t know
Looks close, or possibly just like a 1911 Vintage Excelsior Auto-Cycle built by Excelsior Supply Co. Randolph Street Bridge, Chicago, Ill
Could be off of a different brand, but definatly a motor cycle engine.
abriggsman
If im not mistaken that appears to be an early harley davidson single cylinder cycle engine. Possibly250-500cc
But I could be wrong. Its hard to tell without actually seeing
it on person. I would check with vintage Harley Collectors first
to get a positive ID on that engine.That would Be your best start . Good luck to you:wave:
S
speleausmining
There was a thread like this a little while ago, I think the concesus was that its a motorcycle engine. I dont know what brand or even if the brand was identified. but then engine in that thead was almost identical. :rolleyes:
maak
Re: just don`t know
thanks, i will try and get more pics
---------- Post added at 03:17 AM ---------- Previous post was at 03:13 AM ----------
thanks, i will get more pics
Engine Whisperer
Defective Email Address
Whatever brand this is hasn't been mentioned yet. I do not know what it is but I don't think it is as early as the design suggests. The end of the crankshaft is speaking to me, I just can't hear what it's saying. It has flat spots milled off with a hole through the milled area, not threaded on the end to hold a pulley or sprocket. Looking forward to seeing some pics of the other side.
---------- Post added at 11:00 AM ---------- Previous post was at 10:56 AM ----------
Holy Cow maak, just noticed, almost 4 years between posts? :wave:
SteamfanMN
I'm no expert by any means but I am convinced this is not a Harley as they had a external rocker arm and they had their name embossed on the bottom of the crankcase and a serial number at the top of the crankcase where the cylinder met and there was also a number on the base of the cylinder too. Also with Harley's they had a magneto this one appears to have a battery and coil system since I don't see a bracket for one.
Could be a lesser known maker, most older big names had their names embossed on it somehow.
SteamfanMN
Thanks for the correction Bill, that's what happens when I don't double check my facts I send out BS :bonk: I got a friend who may know I'll talk to him tomorrow.
