Kohler 3.5a21 Carburetor rebuild
Kohler3.5a21
Hello all ,
I bought a kohler 3.5a21 lite power plant last winter and I have been google searching for days now with no luck. The gen that i have has the l600 engine, I am trying to find a diagram of the carburetor. (yb-a2) I dont believe i have all the parts to it there is some places that looks like things are missing , like a glass settlement bulb and also some open ports on the carb,
Any help i could get would be greatly appreciated!!!
mmcdonald
The carb is YB-2A or 2B etc. number first. I do not have a diagram but do have a few NOS parts in stock. If no one supplies a diagram for you, I may be able to answer some questions if you have pictures. I have worked on a handful over the years. If you search on smokstak for L600 manual you may find some info possibly.
Vanman
What is the serial number and spec number on your Kohler? I have some manuals that may be of some help.
Keith
Kohler3.5a21
Serial number for the carb is 240460a, I did find a picture of the carb but it does not help much
---------- Post added at 12:17:38 PM ---------- Previous post was at 12:16:08 PM ----------
Model number is Kohler 3.5a21 4 cyclender l600 engine
---------- Post added at 12:18:41 PM ---------- Previous post was at 12:17:38 PM ----------
sorry miss typed it YB-2A
---------- Post added at 12:20:50 PM ---------- Previous post was at 12:18:41 PM ----------
what parts do you have i am missing some parts for the carb
---------- Post added at 12:25:18 PM ---------- Previous post was at 12:20:50 PM ----------
Here is the picture i found i am missing the cap on the bottom of the carb
mmcdonald
Not sure what you're calling a "cap" unless its a plate on the bottom. I "think" that carb was set up so it could function in 90 and 180 air draft configurations and I think that cap could be screwed on either port that wasn't used(but I'm going off 10 year old memory or so). If I am on the right track you'll have to make the "cap" more than likely, I think it's just a flat piece of metal. If you're talking about the slotted plugs they're just 1/8" NPT you can get many places. I don't have much for parts but think I still have a gasket set, needle & seat, float, etc. Maybe something else but definitely not the "cap" if we are talking about the same part.
jack0
61
The carb could also be used for tri-fuel use. The knock out plug is removed and a load block is bolted to the bottom of the carb for propane or natural gas.
