Kohler Model D with No Genset Bits
Zephyr7
Re: Kohler model D with no genset bits
Pretty cool! Patents listed from 1908 to 1920.
When was this set made?
Bill
Vanman
Hard to read the serial number for sure in the photo. What is it? We can look it up with that.
Keith
BHoward
Hi Keith. Just went out and looked at the plate . It,s B 1647
Vanman
Hmmm, the chart doesn't have a list for the Model B, but it does state that it was discontinued in 1923.
So... "Early 1920's!" :D
BTW, if you PM me an email address, I can send you the serial number chart. It is only a one page PDF.
Keith
Andrew, I have part of an early one that has 2 compression rings and 1 oil ring. The oil ring holds the wrist pin in.
would you be willing to sell the piston in the photo? i badly need one as i broke one in my light plant trying to remove it.
Scotty 2
Scotty will be along shortly to scold me for pinching his thread:O:D
Hello Paul.
Why?? All's good when people contribute something worthwhile.
For some reason I've missed the last few posts on this thread. I must of been busy or something. :shrug:
Any more pictures of your set?
Anyways, the Kohler is finally home (as of yesterday) so some investigation into it's condition and what's missing needs to be made.
1 HP per cylinder......what a beauty :D
Cheers Scott
PS: I missed a few thanks. Sadly the thanks button is missing so here is my thanks. Thanks to all. :salute:
Andrew Mackey
Actuaal HP was about 41/2 for the earlier units (A thru C). The D, E and 1A or 1 Ms were about 5 HP, due to better carburetion. Up to the C, kohler made their own carbs, which tended to ice up leading to stalling. When the throttle openned, it would knock off the ice, and the unit would then pick up speed. Later engines used a commercially built carb (Zenith I think), which didnt ice up (bigger bore), and delivered more power.
The name of the game with the 4 cylinder overhead valve engines was smoothness - no voltage ripple, and extreme reliability. As long as you kept oil in the crankcase, and changed it when needed, these units lasted forever! The basic engine design lasted for years - from the teens until the 1950s, the internal changes being minor (rocker and push rod design and after the C model, oil rings on the pistons on later D engines). These engines had LOW compression - about 50 to 60 PSI TOPS! Comp. ratio was in the area of around 5:1. 2"bore, around 4' stroke with about 13/8" head space, they were no racers. it was rumored that kohler experimented with the engine, getting up to about 20 HP out of it before busting cranks, but as these are low speed engines, that much power was totally unnescessary
Vanman
Actually they're 2" x 3" engines, but the space above the pistons sure makes it look like a 4" stroke! :brows:
