Kohler model K91EP has engine
ronny p 148
This engine starts hard as heck ! Has intermittent spark pull it over and over but when it does start on square I know not Realy good for it but when it does fire it runs great ! Has external points !
Ogrebeast64
A bit more detail would be helpful. I'd check the ignition timing, clean/gap the points/plug, check flywheel key if applicable, check all kill wires for shorts, and have the coil tested.
gnucklehead
Is it manual pull-start, and what fuel is it running? Most small EPs I've messed with have a bandix-scintilla type magneto, with a (small) magnet ring collar on the crankshaft.. it needs more crank speed as the coil ages, but maybe you can tighten up the gap a little between the coil shoes and magnet ring. The magnets don't have near the speed as a flywheel-mounted magnet.
