Kohler R series manual available here
Ed Sparks
got it fine, 51 pages.
Don't need it right now , but building the library never hurts.
Ed
Kevin K
It downloaded fine. Thanks. I'll add it to my very small collection of Kohler manuals.
BTPost
Staff member
70
It is now in my Archive.... Thanks..
vacuum
Downloaded w/o any problem. The manual is for 1 phase but I hope to be able to use it for repairing my Bubbed wired 3 phase. Thank you
Spam16v
Jumping around like a mental patient right now. Thank you! I see thanks give, where is the option to thank the OP?
Daverepair
If you do a search I posted a 20ROP81 diagram somewhere here.
Look here Kohler shop Manual 20ROP81 spec.13302B28
Correction, Search that in Kohler section
dkamp
eMail NOT Working
Yep... I think Fileswap.com is AWOL, or their DNS has been botched.
12.5R62... I believe that's 230 3phase DELTA, four cylinder Waukesha FC140, 32v battery start, remote connections on terminals 5 and 6 ...
Am I right?
Kevin K
The manual link was an old post from April 2012 and links go bad quickly on the internet.
12.5R62:
12.5 = 12,500 watts
R = remote start
6 = 120/240 single phase 3 wire
2 = Combination Gas/Gasoline or Straight Gas
Read the Kohler FAQ sticky on top of the threads for a lot more information. Unlike Onan, the Kohler model number is not very specific. We need the spec number to find information on what you have. Pictures are welcome and very helpful.
The abandoned link was to manual TP-5110 which covered single phase R series models 5RMY, 5RMOY, 7RMY, 7.5R, 7.5C, 10RY, 10RMOY, 15RMY, 15RMOY, 17RY, and 17.5ROY.
Oldsparks
No, it's single phase either 12.5 or 11 kw with a 4 cylinder continental engine.
---------- Post added at 03:19:17 PM ---------- Previous post was at 03:16:23 PM ----------
12.5R62:
12.5 = 12,500 watts
R = remote start
You are on the money spec wise. The model number says 12.5 but the spec tab says 11kw so which is correct? thanks
Oldsparks
Oldsparks;1536007]Just joined and tried to download the manual for a Kohler 12.5 R 62 to no avail. Said the page could not be found. The problem could be on my end. Any help would be appreciated. Thanks
Some pics of what I have. 12.5KW or 11KW. Need to size breaker. Thanks
Kevin K
Looks like you have an older exciter cranked revolving armature generator with a Continental Y112 engine. Not too much literature is available on those older units. From the controller spec number C-268326F, you need wiring diagram C-268327, which can be obtained from a Kohler distributor as described in the sticky FAQ.
Engine service manual here:
http://manuals.chudov.com/Continental-Engines/Continental-L-Head-F-163-etc-Overhaul-Manual.pdf
And here:
http://pipeweldrig.com/files/weld/Continental L-Head Engines - mnt+overhaul manual.pdf
Parts manual link here:
https://www.smokstak.com/forum/showthread.php?t=152273
