Lets see some picture's of small steam engine's.
Ronald E. McClellan
Mike I live on the top of the hill above Rt. 30 & 100 on the south side. My mailing address is West Chester , but I can throw a rock into Exton. Yes it is West Whiteland. Ron
Ronald E. McClellan
In the front is a well made cutaway model of a Corliss engine. It was made complete with the drop offs to close the intake valves. When I got it there was no governor , so I made one to operate the drop offs. Here is how the Corliss system works. When you turn the crank slow , the valves stay open for the whole cycle. The faster you turn it the governor causes the drop off to work sooner to turn off the intake , and faster will get to a point where the valves do not open at all. In back is a Creators Peanut engine. Ron
Andrew Sine
Great idea for a thread!
Here's my submission for you consideration:
Rochester Machine Works, 3x3-ish twin cylinder, single acting marine engine, utilizing Westinghouse patent rocking valves with a Stephenson Link valve gear.
This engine is completely untouched with a fair amount of original paint, and is a really nice running engine!
Rochester built a self contained safety engine/boiler for stationary applications called the ACME. It utilized an identical engine minus the Stephenson Link. I assume my engine was part of an ACME setup designed for a small steam launch, however i have no proof of that. There are at least three standard ACME engines that I'm aware of, one of which complete with its boiler. I'd love to know if any other marine ACME's exist!
Here is a Rochester/ACME engine I found sitting in a rotted wood shipping crate in the woods. It's also complete, with the boiler and accessories and fittings. It is missing the outer shell and boiler top hat, so I have to make those.IMG_0414.JPGIMG_0535.JPGIMG_0538.JPG
Ronald E. McClellan
This is a one of a kind walking beam engine. I believe that it is an apprentice built engine. I found screws that were in-between standard screw sizes to show his skill. It is all brass , When I got it the brass was so dark that you couldn't tell for sure what it was. It has a 10" flywheel and a 12" beam. Ron
Ronald E. McClellan
After thinking about my answer , it is not quite right. From what I've been able to find out , the first Otto Langen that Wayne built was a 1/7 th scale model in 1991 (built 25). The second one was a 1/6 th scale model in 2000 & 2001 , which is the one I have. (33" H. over all) (built 50). He then built several 3/4 scale models. Then built a full size model . Ron
