Lineshaft Shop Steam Engine
I would like to share my latest acquisition...This is a J.W, LEES. early box bed steam engine that I will be using as a partial power source for my line shaft machine shop museum. I will explain the "partial power" part in a moment. The engine was built in Renovo Pennsylvania.. but aside from that I have little to no information on the maker and its existence...it is a beautiful well made engine. The flywheel on this engine is not correct and has been replaced with a small flywheel at some point in its life... I am searching for a curved spoke flywheel roughly 28-30" inches in diameter give or take with roughly a 4" face... if anyone can help me out with that please let me know. I would also like to put the word out that I am searching for a generator or dynamo from the 1800's to also incorporate into the line shaft shop... This will only to be used for period style hanging lights.. I know very little about the difference between a dynamo vs. a generator ...I believe a generator is AC power and Dynamo DC but information and suggestions on this topic are invited as I am going through the learning process. As for the "partial power" that I mentioned earlier.. I will have the shop completely set up to run on steam but I will also have a gasoline mill engine set up in the shop to depict the period of transition during which a shop may have abandoned the steam power and switched over to a gas engine...this also enables me to run the shop at a moments notice without building steam. Any help on finding a flywheel and finding a dynamo or generator would be much appreciated along with any helpful information or ideas. Thanks George
cncFireman
New member
Re: Lineshaft shop Steam engine
That is a nice engine you have for your line shaft shop. I have been also working on a small line shaft shop.
cncfireman,
How is your shop coming along? What for machines will you have in it and what type of power source?
cncFireman
New member
It had been coming along but I am moving currently. So I will be moving my shop. I have a few lathes from the 19th century in various periods. Two of my engine lathes are most likely pre 1850. I have the same Wilkinson planer you have. I posted a picture in your other thread. And some other machine tools from the 1900s. A couple of vertical steam engines and piles of line shaft hangers and pulleys and raw stock to fabricate the shafts. Overall its a small hobby shop sized collection.
I would love to see your shop when finished... My shop will largely consist of small machines... Easier to manage and fit more in one area... I have lots of good ideas to incorporate into my shop but always looking for different ornate machines to add.
old iron shops
New member
i can probably help you with your flywheel i build patterns so i can make you what ever you need i know im years late finding this post but figured i would reply any way
Thank you for offering..I am happy to say I found a flywheel from another Stak member and it seems like it will be a real nice fit...I will add some pictures when I get some time.
