Looking for info on Onan CK S/656N
ToddGomez
So I am currently working on a Onan motor that is also marked with P1542. I am trying to find service info and could really use the help. It is currently mounted on an EZ GO Golf Cart frame with a custom built vintage fire truck body. I am trying to find any info about the valve adjustment, parts etc. Please help and thanks in advance!IMG_20200624_205715929.jpgIMG_20190523_101754951.jpgIMG_20190710_204648544.jpg
ToddGomez
Hey appreciate your help, do you know what parts may be interchangeable? I need new cylinder head gaskets for this. Found out that the carbon build up was causing the exhaust valve to stay open so it's why it was loosing compression.
