Lorenz engine piston help
Dan thompson
I am working on a 1915 Lorenz engine 3-4 KS (built in Czechoslovakia)that has very low compression. The piston has been replaced at some time and I think it needs a dome on center of piston. Looking for a picture of an original piston or anyone with information on this. Any information would be great.
Thanks Dan
Arnie Fero
Thanks Dan
Dan, Could I have the serial number of your Lorenz for the register? Thanks.
---------- Post added at 12:27:31 PM ---------- Previous post was at 12:25:43 PM ----------
Hello
This 3-4 hp Lorenz has a flat pisten:
And this 4-5 hp too:
Chris
Chris, Could I have the serial numbers of these two Lorenz engines for the register? Thanks.
jbo.aermotor
71
Dan,
I have a 3-4hp Lorenz,ser.#13351, It is a good running engine. I got it from Harry Terpstra about 10-12 years ago.
motorenbau
Hello
Dating of Lorenz engines is rather difficult. Most of the comanpy´s archives seems to have disappeared during or after WW2.
If you have a (German made) Bosch magneto on your engine you might try to date it by its serial number or manufacturing code (e.g. "12Y" or "II L"). I have a list that explains these codes.
Chris
Harry Terpstra
Ed, Do you have a picture of your engine? I've had a number of Lorenz engines in the past. I'm sure Arnie Fero can help you with a lot of information.
Harry Terpstra
Ed, I found that Lorenz build their 10.000 th engine in 1930. There are various differences between Lorenz engines. The earlier 4 hp engines were heavy (about 1400 lbs. Yours is a later style with the rounded top of the cooling tank. I think your engine is late twenties.
