Model T Ford Blocks?
I have a Worthington tractor with a model T Ford engine. 1925 I think. With starter. It has a scorer cylinder from a loose wrist pin I have found a 1915 block. It’s a couple hours away from me. I live in 28325 NC. Will the 1915 block work to replace my 1925 26? Or are they diff
Jake Jacobs
Re: Model T Ford blocks ?
What is the number stamped above the water outlet on the side of the block? 1925 block is different then the 1926 1927 block. Early block may still work.
Bryant
I don’t think it will have a place for the generator
uglyblue66
That 15 block is of much greater value than a 17-25 block. And no generator mounting .
Tracy T
cant help on block interchange, but you can have a sleeve put in your block and its not as expensive as one would think.
gleaner
Go ahead and get the 15 block. If it is good you can sell it for about what it will cost to sleeve the 25 block.
The 15 block will work but you will have to change the generator and timing cover. Also if the 15 is complete and a true 15 then the flywheel will not be machined for a ring gear for your starter.
My advice is sell the 15 and have your block sleeved.
uglyblue66
The pm didn't work for some reason.Look for the website for Tarheel T's here in NC and if I aint bad mistaken a couple members have a good inventory of later blocks that you could buy reasonable for your project.
Duey C
55
Ya, the 15 blocks are starting to get scarce. Like the guys suggest, get a newer block or fix yours.
