MOUNTING OC MAG ON 12HP REID
T
Tom Weatherford
DOES ANYONE KNOW WHAT THE BRACKET LOOKS LIKE THAT YOU USE TO MOUNT THE OC MAG ON A REID 12HP? ANY DIAGRAM OR PICTURES APPRECIATED. THANKS TOM
M
Matthew
Tom,mine is mounted with an L shaped cast bracket.Bolted to the bed with one stud and nut, although the bracket has two mounting holes.Probably is made to work on both left and right style engines.Sorry can not post a picture but can answer any questions.Matthew in WV.
