My 10 Dollar Delco
Mike Unwin
Just back from a great auction where on the spur of the moment came home with this project . What I can say for sure is the one tag must be the serial number and reads 325400 and the other tag reads Delco - Light 750 watt 32 volt .
On the flywheel there is a long casting number but also a short one 12-13 does that mean anything ?
I realize it is missing the covers but can anyone say what model it is ?
Hard to matched it for me as I am not familiar with them, it was completely seized but now only the exhaust valve is .Work for tomorrow ,was on another site but could not make a match .
Thanks Mike
Mike Schweikert
53
I'd say its a 752. Looks like the one I had. That's the model that will self start with a 300 watt load on it. The lever on the side when turned down forces the throttle open for battery charging. Appears you are only missing the top cover, not a real issue. It would have had a 5 gallon metal can for fuel, with two small pipes on the top. One side would have a tube going through the pipe to the bottom which was attached to the fuel pump, the other side was for fuel return, as the carb only held a little bit and was an overflow type.
It has a few solenoids in it. Make sure the contacts are clean:)
Mike Unwin
Thanks so much I believe that,s it ! A Model 752 now I can hunt down a manual. After watching the video I see all my missing bits the top cover ,side generator cover and the door with a amp meter in it .The door will be easy to make as the hinges are still on the generator . So I need a couple of 32 volt light bulbs for a load and a 6 volt battery to crank ?
Can it be dated by the tag number 325400 ?
Hope I don,t drive you crazy with questions but every since I was a kid and watched Green Acres I was fascinated with the little power plants.
Can a 12 battery be used to crank with frying the circuits ?
Cheers Mike
---------- Post added at 09:46:31 AM ---------- Previous post was at 09:27:35 AM ----------
So what I have seen is I need two 12 volt and one 8 volt battery to crank and run ,the years might be 1929 to 1932 .
Now I understand why you see so few at the shows it will need a 8 volt battery to complete it .
Cheers Mike
Tim B
I use 3-12 volt lawn mower batteries for my 32 volt lightplants. I just take them out of my other lawn tractors for show weekends. I have also used 3-12 volt light bulbs wired in a series before I found the 32 volt bulbs. Hope this helps and keeps some of your cost down for you.
Walmart did carry the bulbs and batteries.
Mike Unwin
Okay Tim I do have 12 volt batteries here ,just back to cleaning it now found some great Youtube videos on the Model 752 .Cheers Mike
Mike Unwin
Worked some more Sunday on it pulled the jug off to free the exhaust valve, it will need a new valve and rings to be right again ,the rings are stuck in and will likely break coming out . So I filled the sump with fresh oil put it back together and sprayed the outside with Krown to protected it until the time comes to rebuild it . Been a interesting project well worth the price ;) . Here is a sight familiar years ago working on the Delco Light plant by the light of a Coleman .Cheers and thanks everyone Mike
