Needing some help with a crankshaft seal for a Wisconsin AGND
CharlieHasaHarley
Im restoring a (bout) 1978 Ditch Witch M 422. Took the pto/clutch gear deduction unit apart cause of some water in the unit. Also replacing the bearings/races
Decided to change the crankshaft seal since I was going thru the pto and not knowing the history of the machine. There is no numbers on the seal
As you can see in the pics the seal isn't cork but rubber. I need to be pointed in the direction to where I can find this seal I prefer rubber over cork
Zira
Staff member
Standard seal is HF-236, which is listed as cork.
Tracy T
If you have a hydraulic shop near by, take your old seal and your shaft measurement with you and they can hook you up, or a bearing supplier.
CharlieHasaHarley
Wondering what book are you talking about? I didnt get any books with the ditcher or motor
