New sparkplug tester help
C
Chris Page
Help got a new sparkplug tester and I think I broke it I hooked the clip to the sparkplug and nothing happened, also what does the long needle type thing go into
Please help
John Newman Jr.
64
At first glance, it looks like what you have is an automotive continuity tester. A 12V light bulb in the handle will glow when you hook the alligator clip to any grounded surface and touch the pointed tip to a live wire. Very useful for checking out trailer wiring, but there are lots of other uses too. It is possible to replace the 12V light bulb with a small neon light and it will work as a spark tester, but be careful how you hold it. It may not be insulated enough to protect you from 30,000 volts or so. If it is, indeed, a sparkchecker, you should attach the alligator clip to ground and touch the tip to the sparkplug terminal.
grub54891
62
It does look like a test light but,I have one that you can unscrew the needle and put it in the other end of the tester to check spark also.Mabe it's one of those types???
grub54891
62
Also In your pic I see you have it hooked to the sparkplug,It should be hooked to the coil wire(the wire that hook's to the plug)And grounded to the block.
KEB
Some test lights have a neon bulb in the handle to serve as a spark plug tester. Hard to tell from the picture. If it contains a small bulb, it's a 12 volt tester. If it contains a neon bulb, then it can be used as a spark tester.
Anyway, the clip goes to ground and the pointed probe goes to whatever you're testing. I have one that has a place to screw in the probe on both ends. If I screw the probe in on the handle end, then it connects to the neon buld and words as a spark tester. If I screw it into the normal end, it connects to a small 12 volt bulb and words as a normal test lamp.
Connect the clip to ground and put the probe on the spark plug terminal with the engine running. If its a regular test light, nothing will happen except you might kill the engine. If its in fact a spark tester, you'll see an orange neon flash every time the plug fires.
Keith
Turbo
That is a TEST LIGHT not a spark tester:bonk: It has a 12 volt bulb and illuminates when a 12 volt circuit is connected. Clamp the alligator clip to the NEG side of your car battery and the long point to the positve side and whala illumination:D
