Onan 20es spec 79794G set up help
CenTexBear
Thanks in advance for the help. I’ve been looking through other Onan posts and it seems like there is an over abundance of knowledge on this site over some others so I’m coming to the feet of wisdom.
I just purchased this Onan 20es spec 79794G. It came off of a small medical facility and was set up as a standby system. I didn’t get any of the standby control system. I’ve been trying to determine how far this will push 3phase. My plan is to connect to mine and my parents houses, obviously only for essentials in each house, which are about 400ft apart. DoI need to place the gen at a mid point and run wire both directions, or can I put the gen at one house and run one direction? I will be feeding the unit with 1” from a 500gal tank.
Birken Vogt
Email NOT Working
You got a good generator if it is in good shape.
This is a job for an electrician who is experienced in generators. It is not a DIY project.
CenTexBear
I will be the first one to back away from electrical work. I am not trying to wire it in. I am trying to figure out where I need to place the gen set so that I can have someone wire it in. Can anyone tell me how far it will push electricity?
Wayne 440
A generator does not "push" electricity any certain distance, it is an essentially constant voltage source . The distance from the generator to the point of use and the anticipated load determines the size of the required wiring. There are a number of other factors besides the wiring path(s) and expense that should be considered when placing the set. Distance from the fuel source, ease of service access, noise and exhaust fumes are a few. You almost certainly need on site advice from a person with installation experience if you wish to have a reliable, well functioning installation.
CenTexBear
ok I've got another question. I switched it over to Gasoline today and tried to start it. The ignition switch in this particular unit is a three stage switch with "remote" "Stop" "Start" positions, It had a standby system on it previously. When in the remote position you can hear a relay in the board trying to engage, but when you push and hold in the start position nothing happens. Is there supposed to be a wire going from the battery to the ignition switch or something?
zuhnc
All the Onan Guru's are on the Onan board. They can answer any questions you have as to the capabilities of the generator. Search the forum for Onan generators. For your residential applications, you should reconnect the set for 120/240, single phase. This gives you a full 83 amps output. This set is capable of 20KW at 120/240, single phase. Most likely it is connected for 120/208, 3-phase, now. Unless either of your residences use 3-phase, reconnection for single-phase is the desired output. zuhnc
