Onan 5.0 CCK 3CR/318400R
Onan Dan
Serial number E770232314 going to pick this Onan up tomorrow it is tri/fuel ran good last time it was used and now it turns over very slow will not start I made him an offer he said come and get .:)
YellowLister
Cool! Brushes? Lose connection or bad start solenoid.. just picked up a 5.0 cck myself.. going to make a cart for it today.
Onan Dan
The fellow ran it on propane so really should not have to do a lot of changing to run it on Natural gas at least I do not think so?
gnucklehead
That's a nice one :D:salute::D
Just a minor tweek of the main load block should get it started. Your carb might have two valves on it for loaded and unloaded adjustments.
Onan Dan
Got the 5 CCK home the motor is free turns over has compression got the rubber mounts and all hard ware two regulators it is factory vapor tri/fuel
He said last time he used it would not turn over very fast and did not start I said how long ago was that he said 5 years ago so we know it needs some TLC any how got to get ready for tomorrow 10 am hernia surgery so my Onan is on the back burner for now.:eek:
Hope the surgery goes well and make sure you listen to the Dr. on the recovery process!!!!
Ed Sparks
NO LIFTING ANYTHING for a few weeks.
You don't want to pop the internal sutures loose.
Ask me how I know:bonk:
getting it fixed the first time was bad enough, going back six weeks later to get it redone was much worse.
Onan Dan
Thanks folks for the prayers and good wishes Things went well with surgery I got home last evening doing ok on strick orders no lifting so I think I will do my research on this 5.0CCK here is the model number the way it is on the tag 5.0CCK 3CR 31/8400R serial number E770232314 Could some one send me the parts and service manuals for this onan some time no hurry? Thanks:) Ed man that is some good maple syrup we had buck wheat cakes for breakfast this morning :D
grif
New member
HE MEANS NO LIFTING!!!!!
Don't do what I did. you end up back in surgery to re-fix the surgery site.
Just Don't Do It!!!
And good luck with the recovery.
Onan Dan
Thanks mike I have a lot of time to study the manuals the ole body is hurting this morning where I had the hernia repaired .
MBB
New member
Well just sit back and read some of that Onan Porn. Hope it heals fast. It is He$$ getting old. Im really moving slow today. It might be the weather. Have a good day Dan.
