Piston clearance
B
Brad Franken
Had my 2 1/4 United running for about 30 min. I think maybe it needs a bit more piston clearance. With a 4" bore what do you think the max piston Dia. should be? I had a new sleeve installed & it measures exactly 4" The piston is 3.994 Thanks Brad
K
Kevin A. Behnke
The clearance should be good for cast iron pistons. I have had in the past, tighting of the piston pin retaining bolt will distort the piston enough to create a tight spot on the piston. If this happens use prussian blue to find the tight spot and file off the high spot.
M
mark
you should have .003 to.005 clearance.check at the skirt 90 deg from the wrist pin
