Pump Designer on Drugs
G.M.Johnson
Re: Pump designer on drugs
I'm going with the principal of centrifugal force. Water enters through the middle and by way of centrifugal force, forces the water out of the tubes, to the discharge port. It probably actually made some good pressure believe it or not. Take a piece of copper tube, fill it up with water and then whip it and see how fast the water comes out!
Scotty 2
I think hydraulic motors are fed from the outer side of the " impeller" to exert the main energy onto the biggest diameter and then be expelled through the center. It might work with pressure from the center but i dont think so.
If it did then it wouldn't be with much force with the head height pressure from an overhead tank. 20' height height is a bit less then 30 PSI though.
Cheers Scott
Darryl
Centrifugal force is what its all about, there's no doubt but the main thing with any pressure pump is sealing the impeller inlet to the suction pipe as it will just recycle more and more as the pressure goes up
typak
Just a type of 'closed impeller' pump? and not a 'open impeller pump' .......:shrug:
DaveMisch
I agree with Johnson in 21. The impellers don't make any near contact with the sides of the pump. They are throwing the water out by centrifical force putting pressure on the outlet side and a suction on the intake.
Darryl
It is a centrifugal pump, there is no question about it. It's just a stupid but interesting idea.
Scotty 2
So have you tried it out yet Darryl? I'm pretty curious on just how well it pumps.
Cheers Scott
Darryl
Hi Scotty, no,not yet.
In the middle of India at the moment. Seen a thousand real Listers and twice as many Indian copies on the side of the road usually powering compressors . Went past a big farmland in a car and spotted a big Ruston Hornsby pumping water ,just out in the open. Also saw a McDonald road roller still working. Before you ask, I don't have photos because we were in a hurry driving somewhere yesterday and did 800 kms. Will get some though.
Ifix71
The designer didn't know about cavitation, drag and hasn't looked at anyone else's impeller design in my opinion.
I just keep thinking , WHY ?
The liquid being pumped is drawn through the tubes by centrifugal force from the central opening The suction can be quite substantial at higher speeds possibly more efficient and pump at a higher pressure than a traditional centrifugal pump. somebody with more time and a good Calculator can do the math
John
Oil Power
Here is another unusual centrifugal pump. Patent No.4655 taken out in 1886 by John Abraham of Ballarat. It may have never been made or worked. He claimed to be a teetotaler!
Hugh
