Ready for Wet Sand Blasting
cobbadog
Fuel tank sorted and tested with fuel inside and it stayed there!
It is now in etch primer waiting for the next step.
We are expecting bad weather to arrive here from tomorrow for a few days with possible rain. Now that is a no no right now but I can't change that.
So in the mean time I have been playing around with the wells of the wheels. They were not blasted, I forgot about doing that area so I have been into them with a wire brush on the angle grinder and a chisel to loosen up the layers of rubber bead from old tyres and a small amount of rust near the valve stem hole which is normal. I will spray some Rust Guard on the inside of the wells to help protect them for the future.
cobbadog
All the wheel wells are now cleaned and painted to help prevent more rust on the inside. I used Rust Guard epoxy enamel which once dried is fairly hard stuff. Colour will have to wait as we are expecting a cold wet change to hit here over the weekend so I will have to wait until that passes.
So I have now started on being a plastic surgeon again (repairing the tinware) especially on one mud guard. It had a hit or rather it was backed into something and the damage went back further than I originally thought but in time that will be sorted as best I can.
Damn pics are still falling over. Never had this issue before and I'm still using the same phone and windows picture manager to rotate and save the image before posting.
cobbadog
Well yesterday was drizzle all morning then late afternoon sunshine but too late to start spraying. Today was just perfect weather for the spraying to start. So I warmed up the compressor, blew everything off and started mixing and spraying. I got the tractor skid done although in the pic there are some places still waiting to get covered. Even now all I see is RED so late today I had another look about and found a couple of small spots I missed so they can be touched up later. I started with painting the rims as I want them to harden up properly before getting the tyres fitted back on and then back onto the skid. I am pleased with the colour and the way it went on but I ended up using slightly less thinners than suggested as it was a bit too thin and runny.
Progress at last !
Scotty 2
As flash as a rat with a gold tooth Cobba. Well done. :D
How many weeks until rusty iron? Is the pressure on to get David operational again?
Cheers Scott
cobbadog
No bloody pressure at all and there will have to be enough weeks until the RIR. That is why we are taking off to Shitme for 6 days later this week just to make it easier to get this project done.
Not only that the radiator had to be taken apart and not long after cleaning out the cores the bad news arrived and it is a right off as far as the core is concerned. So it is a re-core at a huge cost, too frightening to think about.
So to make me feel better I put his face together today. This does make me feel good!
Scotty 2
Oi Cobba. Missed a spot. :D:O:brows:
Looking real flash. It's pretty sad when the tractor has a better shine then the car. Well my car at least. :(
cobbadog
Here is today's stuff up. I never did have or will have the ability to have a steady hand OR the ability to do fine work.
Here is the proof!
At least no one will ask me to do a similar job for them after seeing my effort on my tractor. It is going to stay this way and I can live with it and I also can say that "I did the bloody lot" and here is the proof. :eek:
cobbadog
I am suffering with " foot in mouth" disease.
I can't leave it as is so I have touched it up with some yellow and will do the smallest touch up on the red in a couple of days.
I can be my own worse enemy at times.
Dobbo56
Cobba forget the dog it will find it's own way home, keep on pushing on, looking good will be ready to take some happy snaps at RIR. See ya there
Dobbo56
cobbadog
Thanks Paul. I now have to plan around work and take some time off to get somewhere near done by then. It looks close but in fact I still have a way to go with all the little stuff.
Yep it will be good to catch up at the rally..
cobbadog
Had another 'spray day' today and it was just that.
It had a gastric attack and got the runs in a couple of palces so I will have to see how bad it is tomorrow and take the appropriate action.
cobbadog
Did a trial fit with the remaining tinware as none of it was original to this tractor and once confirmed it all got painted and the runny bits were rubbed back and re-sprayed. I have almost finished the electrics and yes I have levelled up the gauges that were crooked. So hopefully this weekend it will be all back together again.
