RIDER ERICSSON 6" - Brick - Cuir Piston Gasket
Marv in Minn
Re: RIDER ERICSSON 6" - brick - cuir piston gasket
Hello,
the pump packing has two 1/4 "threaded holes.
It is original?
In the hole I have to put a tube to recover water leaks?
Thank you
Davide
yes, the holes are for a drain tube in one and a plug in the other hole.
it is normal for the packing to leak a little.
if you tighten it enough to not leak, it creates too much drag on the engine.
marv in minn
colo
46
marv in minn
Hi Mrv in Minn,
thanks for the information.
I have a new question, how should the pump packing gasket system be composed?
I have: pump + rubber washer + brass washer + rubber washer + brass stuffing box (with cone to house the packing).
It's correct?
Marv in Minn
It's correct?
yes, that will work.
colo
46
I'm almost there, today for the first time I saw him move .... it's a show !!!!
I had a leak on the pump packing, but I've already solved it,
It's fantastic: a handful of wood, 10 minutes (but I would say even less) and the engine starts, fantastic!
Now just a nice outdoor video is missing, with the right light and perspective.
---------- Post added at 07:55:25 PM ---------- Previous post was at 07:51:42 PM ----------
I was afraid of not succeeding with the power piston seal.
I was afraid of the friction due to the glands and the pump, but instead everything was perfect.
Without water the engine goes very fast ... too much .... it was a great purchase !!!
Cajun Pickers
Re: RIDER ERICSSON 6" - brick - leather piston gasket
Hello,
I’m restoring an Ericsson engine with a 5 in. power piston and im looking for some information on the main leather seal. I think the seal I have is going to need replacing, and so I was wondering if I could get Don Worley’s email.
colo
46
I need to replace the gasket that is in between the top and bottom cylinder halves. What are y’all using to make this gasket?
Hi Cajun,
Are you talking about this?
image by Davide Coloretti, su Flickr
I used graphite fiber gasket, gasket material for gas or steam engines.
Then I covered it with a light layer (red) of Motorsil Arexon (silicone caulk for high temperatures)
