Standard Twin Starter Pulley
Jeremy Williams
31
Hi,
Does anyone know if a starter pulley with part number C425 will fit a Twin? I currently have a rope start pulley on, and it doesn't work so well.
Jeff LaCrone
There is a correct one on ebay right now. It's the accessory flat belt pulley one. It would be easy to make the hand crank lever for it. You should be able to dig one up somewhere.
1938Sears
Just curious if anyone has an extra one of these around they would like to part with at a "fair" price. :shrug: I have a twin also I would like to put one on.
Jeremy Williams
31
Thanks for the replies. For that price I guess I didn't need one. I didn't pay that for the whole tractor! Was this one a special option or the standard one seen on most tractors?
Jeremy
pharmall200
These flat belt pulleys were and option that replaces the crank hub on the flywheel. It uses the same hand crank for starting that the original hub used. The small diameter and relatively slow rpm's of the Std twin engine limit the use of the pulley. Some later ones have a v-belt groove machined into them. I have 10 Twins currently & 4 pulleys. Some one brazed a larger flat belt pulley over the original to increase the belt speed so that it would run a feed mill. The kind of money that one brought almost tempts me to part with one of mine.
Jeff LaCrone
I've had close to 20 twins in various conditions and have two of the belt pulley's and one for a v belt that came on a Viking Twin.
I may have a spare crank hub. I'd hate to pull one off a complete engine I do have some parts machines I'd get rid of but I'm in Kansas. I'll check on the spare hubs.
mrf1002u
Hi,
In case you never found out...I have one and the part # is in fact C425. So yes it fits. FYI I also bought a pretty nice reproduction crank start handle on ebay.
Larry W.
