Sturmey Archer Carburetor
Alan Williams
Morning
I am involved with the local Museum here in Waimate South Canterbury New Zealand, They have a number of vintage mowers rotary hoes etc, that I would like to get running.
First up I am attempting the Ransome Sims and Jefferies 30 inch Mark XI number AD1032. Fitted with a Sturmey Archer Engine ?, Ignition is a wico series A base mounted magneto (chain driven ??) I have spark, but cant seem to get fuel to cylinder, any help advice will be greatly appreciated
The carby is the same as that fitted to Regs mower Smok Stak post 5-19-2008
Weezer
Re: Sturmey Archer Carburator
Have seen Sturmey Archer made bicycle parts here, never knew they made engines.
dkamp
eMail NOT Working
Sturmey Archer made moped motors as well... but they were not common to the USA...
DTurner
Can you do a vacuum test on it , meaning from the air intake to carburetor,the manifold to valve? That tells me so much as to the health of an engine . Block off air to engine and put cylinder top dead center so valves are closed and watch the gage if it bleeds down rapidly. If it holds then it should siphon fuel ⛽ ,then the carburetor has a restriction for example in the fuel system . Or a mating surface is leaking .
I also assume it has compression.
Good luck
DTurner
I got a three speed gear hub on my 1953 French automoto bicycle , works great. Now that I understand them . Don’t want to crush the cashews if it disengagement. Ouch !
They first came out with it in 1905 ❓
This is a first for me that they made engines also . Did they make motorcycles ?
grub54891
62
I have a Schwinn and a Raleigh Supreme that I'm restoring. Both have the sturmy archer hubs, wich I rebuilt. Nice setups, but never seen a carb by them.
