Generac: Tailgater.
grub54891
63
Yup, when I bought the camper, it came with this cheap "tailgater" Genny. It worked OK last year but I picked up a better one last fall. I figured the tailgater would be ok at the cabin in case the power goes out for two days like it usually does. The thing is rated for six amps, so I looked up the specs on a small ice machine I have, its only 2.5 amps. The genny would not run it, so I took it home to test, it won't even run the small shopvac that worked last year.
Is it a simle fix on these things, or is it simpler to scrap it? The are only $100.00 new.
Railroads
They use a small capacitor to excite the field. It's likely the cap or the connections to the cap are faulty. If its the capacitor? They are cheap as chips to replace. Essentially a ceiling fan motor capacitor.
They are a sealed epoxy filled type capacitor instead of the oil filled motor run capacitors more common to North America.
Robert
grub54891
63
Thank you. I'll take a look at it sometime this week and see what I find. The thing is relatively new so I'm a but mad it failed so quickly. It's called a tailgator, so I'd imagine its not designed to run much, just some lights and radio..... Lol
turtmaster
Check the voltage, my only other guess besides the capacitor being shot, is the diodes on the rotor.
I've had a few with burnt out diodes.
