Tecumseh Replacement Carb V50-60077E
ellinw02
New member
Looking for a replacement carb for a Tecumseh V50-60077e engine. Looks like someone replaced the carb from a newer engine. The online parts lookup places list carb 631799a as the replacement but there are a lot of parts you can't get. Looks like carb 631101 was the original carb and you can still get most of the parts but there are no service carbs available. Could you buy carb 631799a or even 631800a and use parts from 631101? Also what parts do you have to buy when you get a service carb?
gdstew
Active member
You have to swap out the throttle shaft or transfer the top plate off the old one on to the new carb. Also need to transfer the choke shaft assy.
ellinw02
New member
Got service carb 631799a and it has an extra hole that goes into the carb circled in picture. What is that hole for? Do I just need to plug it with something and if so what do I plug it with? I got service carb 631800 for a different engine and it just has a flat spot there in the second picture.
