Thomson-Houston Dynamo
Fred Prichard
Here is one I owned back before digital cameras were around. It came with a very large black slate switchboard complete with all gauges etc. My very first quality sideshaft ( about a 3 HP Hamilton) came from the same barn. In those days new things came along about every week so both were traded off for new toys. Fred
OttoEngineMan
Hi Fred, Thanks for sharing and I sure prefer the picture of it on the left by far...Let me know if you ever hear of one come up forsake please..
m_thompson
There is a large one at the NEWSM.org connected to an Armington-Sims steam engine. I can take some pictures of it the next time I visit.
OttoEngineMan
If anyone is aware of possibly a original condition one forsale I sure would appreciate a heads up about it. I really like the looks of the ARC Lighting ones too. Was lucky to find several really nice Biplor motors at Coolspring last week..
t6299fm
I have a TH lighting Dynamo 6kw 125 volt. That is similar to the one pictured. It is placarded at 2200 rpm.....FAST for 1885. I will restore it one day as a companion to the Edison 6KW
t6299fm
Be careful with that thing...There are 20 Edison's for every Thompson Houston
diggin4s
The Edmonton Power Historical Foundation has this Thomson Houston generator, was to have been originally from OHIO, note the ephf.ca Edison & Thomson Houston are being "motored" for display purposes as that our building footprint has no provision for suitable drivers & we are unwilling to run these units at or about original rpm's, unit weight is 4400 lbs & the "ball" armature is approx 675 lbs, the control panel is a slate re-purposed panel from 1915 Edmonton Power Plant
https://www.ephf.ca/Blog.asp?id=100&title=Thomson-Houston-1880s-Dynamo-Generator
diggin4s
Looks nearly identical to the one at the NEWSM.
The NEWSM unit is 28 light, the EPHF unit is 30 KVA DC output & 4400 lbs, EPHF got what was available in area & were advised to pursue a Thomson Houston, EPHF would have been happier to have had a Thomson Houston AC version of what was run in 1891 for the Edmonton, North West Territories street light system but it had a 1000 volt output & required 1000 to 52 volt transformers which likely went to WW1 metal salvage a EPHF volunteer created a full scale display model of the AC unit TH Paul collis replica copy.jpg
