Tips 4 Cylinder Engine Adventure
Dwayne Fuller
On Valentines day JR and I went down to Leander, TX (278miles one way) and removed the flywheel from a Tips engine made in Austin , TX. It came out of a cotton gin in Maynard, TX many years ago and has been setting outside since. This engine is close to scrap but I am going to try to save it as it may be the only 4 cylinder Tips left. The flywheel weighs 2,000 lbs and the crank diameter is 5 inches. After the wheel came off using a 50 ton porta power and a 20 jack, we dug around the skid and found the engine had been setting here so long it had sunk 6 inches in the black dirt.
Dwayne Fuller
Tips 4 cylinder engine adventure
Fast forward to Feb, 27th. We took the big truck and trailer plus my 1 ton truck and trailer and headed back to Leander. The engine owner had cribbed the engine up in the air 38 inches so all we had to do was back the trailer under it and start cribbing down. Bad news showed up when I looked under the engine and found hard water had been in one of the main bearing oil reservoir. Like I said this engine is close to being scrap but I hope to save it.
We cribbed the engine down and got it loaded on the trailer with very little problems. Once we got the engine out on hard ground we backed the Volvo totter home under it and loaded the flywheel, mufflers, and a piece of I beam for another protect.
Dwayne Fuller
Re: Tips 4 cylinder engine adventure
last of the pics I took. As usual on Friday I forgot to take any pics of the unloading. JR will have to add some of his pics to complete the story. After everything was chained down and money changed hands the engine owner ran us down to the local pizza place where we ordered to go. Brought it back to the Volvo and ate it with a cold adult beverage. Man that beer sure was good after a hard day of work. We laid down for a nap about 8pm and set the alarm for 10:30. No traffic and cool roads on the way home! We pulled in the driveway at 4:00am on Friday morning. JR hooked the red dodge to the trailer for the short trip from Tatum to my house. We crossed the scales at 34,290 lbs GVW. Sure clad the DOT guys were asleep. The engine with skids attached weighs 17,500 lbs. Now the fun begins.
I could not have done this without the help of JR. He is a true engine friend and is always fun to go on engine trips with. I'm sure JR will get even somewhere down the road, when he says load up I'll be in the seat!
OrgWayne
73
Are the washtubs worth any thing ?/!
Ed Sparks
want to see more photo's of the toterhome.
SWEET rig:D:D:D
ScooterBob
Nice score Dwayne. :D
Will you be building a lean-to onto your lean-to to cover it?:shrug:
Todd Hodges
I think you can have it running for your crank-up in April if you hurry
Dwayne Fuller
The wash tubs are a perfect fit over the heads. They are not vintage as they were bought a few years ago at a hardware store in an effort to keep the water out.
SWEET rig
Yes that toterhome is one sweet ride. It didn't even hardly notice the load where as the 1 ton was grunting! JR even lets me drive it out on the open road where I don't have to shift to many gears.:D It is an 18 speed, that is too many holes for me.
Thanks Bob, Are you guys gonna make it down again this year for my gas-up? I think if the Tips is made to run it will get a new building big enough to put the Tips 2 cylinder and the Tips gasoline horizontal in. Kind of like a mini Tips museum.
Todd, I might have it running if you loaned me Jake for a few weeks. Problem is he has to go to school and I have to work to much. Plus I'm not sure I could afford the food bill. I know how much teen age boys eat.:eek:
Todd Hodges
spring break is coming up in a couple of weeks you can have Jake then I know he would enjoy now I know why you didn't come to Temple or Granbury
TimM
Dwayne its not even close to being junk! Coolspring is as far as i usualy go but if you get that Tips running i would come to TX. It would be nice to see some new country.
ScooterBob
Can't do it this year. Gonna be busy with a big project at work in April, and we just ran off to the Florida Flywheelers show a couple weeks ago.
But we will try to get down there again in the next few years to check out the TIPS museum.
Thanks for the invite, Bob
Dwayne Fuller
Thanks for posting the pics, JR. I sure wish it would warm up enough I could fill all the mains and cylinders with used oil so they could start soaking. If it ever warms up here I will take a few picks of the good and the bad that a quick look yielded. When I took the bolts loose on the intake port cover for #1 about two cups of water ran out. Sure wish this engine had been under a shed the last 30 years or so.
Ed Sparks
Really nice ride J R.
Even has a slide out. SWEET
Dwayne Fuller
Yeah, that slide out sure makes for more room. When JR gets sent to the dog house for buying another engine he don't have to rough it too much.
It sure is nice to be running down the interstate about 70 and the co pilot goes in the back and makes a pot of coffee.
Dwayne Fuller
Thanks for the complements. I went and looked at a three cyl Tips today. It is a basket case with missing parts. Not yet available but I will keep my eye on it.
PTraubert
eMail NOT Working
U got stones for the basket/lost cases.
Too bad steam in the bush is not as common or I would be doing the same.
Patrick - Coming to you from Quito , Ecuador
Dwayne Fuller
Wow Patrick, what the heck are you doing in Ecuador? That sure is a long way from home. Have you found any engines down there? Tips had a sales agent down in Mexico and central America back in the twenties.
