UPDATE -
Old oil seal was tough to get out which necessitated drilling a small hole into old seal. Then, I took a small right-angled pick and hooked it into the hole and "rocked" the seal out via the hole and then, in between the seal and the crank.
I cleaned up the seal seating surfaces and made sure the drain hole was clear. I lightly lubed the seal race (including the concealed spring behind the rubber) and tapped in with a piece of pvc pipe and made sure the outer surface of the seal was flush with the exterior. I then applied some "form-a-gasket" around the exterior race area "for good measure".
I took all the pieces of the generator case and used a Castrol product on each and it took ALL the grime off (still have the engine left to do tomorrow) with literally no effort at all. I took some thread locker and applied to the Allen bolts previously mentioned and screwed them in which mounted the rear generator cover back to the block.
I turned the generator up on it's end and slid the armature down onto the taper and secured with the black bolt previously pictured.
I took the "secondary cover" (the one that was holding the armature from coming out due to a lip that was shown in a previous pict) and installed the 4 nuts and bolts to secure it.
I took the stator and slid that down into place, installed the generators' aluminum "end cap", and secured it with 4 long bolts, and installed the black exterior cover. I put the rest of it together (wires, etc) and started the gen for a few minutes before it began to rain. So, with a few paper towels under it, I will see if my efforts succeeded if no spots. Then, will run until hot and again, look for leaks. After that, clean the rest of the engine and be done with it. (PICTS TO FOLLOW)...
