Venom Winch 12V DC Winch Control
Dwayne Oxford
Re: Venom Winch 12V DC winch control
Kinda what I figgerd Charlie. I need pendant for overhead trolley. Could put relays at motor?
CharlieB
You can buy 110v pendant controllers for less than the 12v one you posted. Even those are typically low amperage switches, so you would still need relays. $$$ :mad::mad: A drum switch is simpler/cheaper.
"Back in the day" (way before OSHA) I worked in a machine shop that had an overhead electric hoist. It had a drum switch mounted on the trolley. The switch had a rocker (see-saw) arm on it and a loop of light weight chain that hung down to operator height. The rocker had a centering spring so that the winch stopped when the operator let go of the chain.
