What is this chisel used for?
RobW
Someone found this in a barn and brought it to the local museum. The total length is 14 3/4 inches and the cutting edge is 2 1/2 inches wide. I didn't measure the step / offset but it is about 2 inches. It might not even be a wood working tool.
Pat Barrett
71
Re: What is this chisel used for
I hesitate to even comment, but it could be a masonary tool to level up a brick in laying it level, somehow.
Tom G
I believe that it may be a butteris, which is a blacksmith's tool used to trim horse's hooves.
Bob Willman
It could be for chiseling a flat surface. The offset gets the operator's hands above the surface to be chiseled in order to protect the knuckles. I believe casket gouges are made with a similar handle offset.
Bob
WB8NQW
Thaumaturge
68
My guess would be either for barrel making or shipwright tool for inside hull planking. Again just guesses.
Doc
Lonnie Grissom
I think tom g is right. I have pictures or these tools factory made. This one was home made in bs shop . The handle gives it away. Tells me that is not a barking spud even though it could be used for such work.
RobW
Thanks for the replies. Unfortunately the local horse farrier historian passed away a few years back so I guess I will have to see if the library has anything on farrier tools that were used in earlier times. Another person thought it was a farrier tool but a fellow that was at our local agricultural fair claimed it was for cleaning out mortises when building barns. I feel that the way it is shaped that it wouldn't work for that. I tend to think it is a farrier tool myself but I would like to see an illustration of how it was used.
RobW
Thank you Sir! That helps to confirm what some others are suggesting.
GarysToys
Here in Lancaster County the Amish use a tool like that to remove wooden shingles.
