What kind of compressor is this?
Blackbeard
I picked up this compressor a few years back. It was hooked up to an old Briggs model Y, but I took the engine off and cleaned it up and got it running, but I set this compressor aside and now I'm wanting to tinker with it. I can't find a tag on it and I believe the color is overspray from auto paint because the Briggs had it too, but cleaned off relatively easily.
Does anybody know who made this compressor and maybe an approximate era it was made?
K-Tron
Im going to say with 100% certainty that it is not a Quincy or Wall compressor. It has an early Devilbiss or Keystone look to it. It appears to be a two stage compressor, but why is the crank offset? There must be two cranks geared together for it to work. Im really curious now what it is. I think some cleaning is necessary to find some numbers or a name.
Chris
Vanman
To me, the part that looks like a second cylinder looks like an air chamber.
Blackbeard
Thanks for the replies.
I guess I'll clean it up with some dawn and my hot water pressure washer. Maybe that'll reveal some info.
I'll be sure to post my findings.
beezerbill
Yes, the second offset "cylinder" is probably a little air chamber receiver. Has no valves on top and has a little water drain valve at the bottom. Not sure what the little doohickey on the output plumbing is - might either be a shut-off switch (if the original motor was electric) or an overload valve that just spits out excess air if the Briggs was the original motor. In any case it looks like it was meant to be carried around by the handle in the center, as if it was originally a tire inflating compressor or general auto shop compressor.
Paul Woodworth
76
You are right Chris It is not a Quincy or A Wall. I have all the early one. I live near Quincy IL. I have a lot of old Compressor, but not this one. Paul
G.M.Johnson
This one has had me stumped as well! I'm leaning towards a very early Binks paint sprayer compressor, and yes it is only one stage with a larger attached finned receiver for cooling purposes.
