What Parts Do You Need?
tgriffin27
Re: What parts do you need?
I am hoping to find a few parts for my Emerson Brantingham 3Hp Type U Engine. I need a Oiler head, Carb, Mag, and ignitor. Basically everything from the water tank forward on this engine.
Winchester
Hi
I am looking for an American Bosch oscillating magneto and bracket for a 1923 Witte I also require a governor. Can anyone help.
Neil
Is that a Type 22.........I just fabricated a bracket,fits the cylinder flange holes ?
robert hamilton
Hi Everyone
Im after Lister A hopper cooled parts the parts I need are as follows
Crankcase door
Carby
Fuel lines
Fuel tank
I also need the following Lister CS 12/2 parts
4 valves
3 pushrods
2 injectors and injector pumps
and 2 injectors pipes
I also need a magneto for a 3-5HP IHC LBBR with the 24 tooth drive gear
Cheers Robert
olman
Hi Thanks for the reply. I am in the process of having a magneto bracket cast. I have an American Bosch magneto which I think I will manufacture the flick mechanism to suit, unless I locate an original. I have repaired the governor. I hope to get it finished this winter.
Neil
rodmart2008
hi Group
after a couple of cooper stover parts for a 3 hp kf model
rocker and rocker stand part numbers are 8k3 and 9k3
Rod
Winchester
Neil did you make a pattern ..........does the fitting of the bracket incorporate the cylinder flange holes . I fabricated mine from 8mm plate stiffened with a web ..looks ok maybe I'll call it a ''prototype'' and a cast one will be next.
Matthew Guy Clarke
I recently aquired this approximately 3 hp Termatt and Monahan. It needs the igniter and tripper. I would like pictures or leads on the parts. The head is damaged too,but repairable. I would buy one if available. Thanks for looking .
Matthew Guy Clarke
I also bought this 3 hp EV Emerson-Brantingham . It needs just the ignitor and tripper. I am willing to make other parts for the loan of parts.
Craig Gillingham
Dont know what it is off but it is surplus to my requirements , anyone want it?
That looks like the bottom half of an early F Model Fordson starting tank.
JeffR
G'day all,
Would anyone have a cast iron carburettor, crank handle and engaging dog for a Southern Cross AKB 3?
Any info would be appreciated.
Regards
Jeff
Scotty 2
Hello all
Anyone got a good second (or new) right knee they don't want? Please :(
A couple of good hands/wrists would be nice too, but I realise that'll be asking too much.
Cheers Scott
steeleye
Hello all
Cheers Scott
I need a couple of grease nipples and a crank handle in each of my knees.
slugga
Hi all,
I have just restarted my quest to restore my old Lister L, I am hoping that someone might have a respectable blind head barrel, as the one I have it seems the bore and valve seats are possibly to rusted to be repaired. Thanks for any forthcoming help.
Cheers Neil.
rodmart2008
Hi Group
iam after some parts for a sundial type b 2hp
bigend oiler brass cap
intake valve spring and retainer
brass fuel pipe pick up
exhaust elbow
exhaust
Maggie wire holder the bit that goes behind the name plate
thanks Rod
Adam Jones
48
Hi guys,
I'm on the look out for atleast one lister CS 3hp catch can. The return from the injector goes into the top of this. Two would be fantastic but one would really help me out.
Thanks Adam
