What size ladle for job?
Russell Walker
I am looking to buy a new bottom pour ladle. How big of one should I buy to pour new Babbitt in crank mains of my Half breed Oil city South Penn. So I can pour each bottom or top in 1 ladle load? I know a #5 is 5" and holds 9Lb. of lead which one should I get the ones I am looking at go up to #8 Which one would you buy? Thank you. Russ
J.B. Castagnos
Do you have an old bearing yo could weigh? You want reserve capacity, dump it in fast, let it spill, if there's a minor leak you can often keep adding until it freezes, an air hose can help seal a large leak.
Craig A
Staff member
68
I had to pour some huge countershaft bearings in a 45 HP Mogul tractor.
I made my own ladle using a piece of 5" or 6" pipe (I forgot).
I welded on a handle and a second short one at 90º so I could handle the weight.
I don't know many pounds of Babbitt were in it when I poured but it was HEAVY....... :uhoh:
Russell Walker
Old brgs. not out yet. Just getting every thing ready. Leaks wont be a problem I got 10 Lb. of Deacon mold pac.
OTTO-Sawyer
58
Where are you buying New Ladles from ?
I have several old ones in various sizes, never gave it a thought they were still available new, but I guess they would be.
:salute:
