Wico AH magneto rebuild
Voltar1
Hi fellas, new here with some questions wrt the mag from my IHC LA engine.
I would like to know how the points backing plate is removed from the mag?
Something behind it is rubbing on the rotor which I presume comes out the back?
Also in the market for a set of points and coil cover.
Thanks in advance
Walter from Alberta, Canada eh!
Gilles Marcil
65
Thanks in advance
Adrian magneto is your best help in Western Canada
Voltar1
Called Rudy at Adrian's Magneto Repair. Chatted a bit then ordered the set of points I need. The point cup is seized up or frozen in place on mine so will avoid removing it if possible.
Voltar1
Thank you Barry. Can leave the magneto alone for now. Waiting on the points which should be all I need.
