wisconsin inline 4 cylinder
N
n0grv
this one is not so small but today I found a wisconsin 4 cylinder air cooled power unit with a twin disc clutch with gear reduction. It has been laying in a junk pile for a number of years and may just end up as parts for some one. I will post some pics as soon as I pick it up. want to find more info on it. JEFF
Bill Sherlock
75
Jeff,
Believe these engines were used on Case wire tie balers, small pull type Case combines and even an Ariens 2 wheel walk behind tractor!! Don't know what application would have used a gear reduction though. I should have some info kicking around.
Bill
