M
Marty
Subject line says it all. I will simply throw in a few of the related details. Have a little (old) single cyl. 250 cc 2 stroke motorcycle. I replaced the piston and liner twice before it was even warm enough to ride this spring. After finally getting everything right, (and nearly $400) I started using AMSOIL 2 stroke oil at a recommended mix of 100:1. It ran very well all summer till last week. I have all my firewood cut for the season and had a bit of chainsaw gas (40:1) left over so I dumped the remainder (about a quart) into the tank of the motorcycle which I am guessing had about a gallon of the 100:1 mix gas in it. I had run an errand on the bike later that day about 12 miles. On the way back, I noticed the motorcycle steadily slowing down as I'm trying to give it more throttle. All of a sudden at about 30 or 35 mph, the back tire locked up and went into a skid. (I think thats what caused the skid marks in my underwear) It took a couple seconds but figured out it might be best if I squeezed the clutch which I did and coasted to a stop. What happened was that the engine locked up, locking up the back wheel. After I stepped back into the real world, I tried turning the engine over and it was TIGHT and hot as H***! I was about 6 miles from home and managed to get a ride, brought the truck & little trailer back and hauled the thing home. By that time, the motor had cooled off and was once again loose but wouldn't start. The following morning, it was reluctant but did start up. And made some god-awful noises so I shut it right back off. Due to lack of time, I didn't pull the cylinder off but I know the third piston and probably the sleeve are shot. I'm hoping it is one more time fixable but not gonna mess with it till late in winter. Details completed, what the h*** happened? Logic says it locked up due to over heating due to lack of oil. I can't understand why adding 40:1 mix with 100:1 mix would coz that? I think there is something very important that I should learn from this and need your help doing so... Thx
